neues Mehrwertsteuersystem in Indien ab heute
markus-1969
Beitrag von markus-1969 »
http://www.spiegel.de/wirtschaft/indien ... 08393.html
Zusammenfassung: Indien hat zum ersten Mal eine allgemeine, einheitliche Mehrwertsteuer, die für alle Bundesstaaten gilt. Die Reform des hochkomplizierten indischen Steuersystems könnte dem Land einen Wirtschaftsboom bringen. Allerdings sind wichtige Einzelheiten der neuen Steuer noch nicht geklärt.
http://www.thehindu.com/opinion/editori ... epage=true
With the adoption of GST, a clear road map is needed to simplify the indirect tax regime
In a landmark reform, India today switches to a new indirect tax system, the Goods and Services Tax. The GST subsumes the multiple Central, State and local taxes and cesses levied on goods and services, unifying the country into a single market, thereby making it easier to do business and ensure tax compliance. This will attract investors and more efficiently mop up revenues for the exchequer. The reform has been years in the making, and having shown the political will to finally pull it off, the Central government must work with the States to chart a road map to simplify the tax regime. Currently there are multiple tax rates ranging from 0% to 28%, plus a cess on some products, creating incentives for lobbying and rent-seeking. The level of preparedness for the new tax system too is not optimal, with sections of industry, trade as well as the bureaucracy visibly anxious about several aspects of the GST’s operational and legal framework. In response, the date for businesses to file the first GST returns has been deferred. The generation of e-way bills for moving goods worth over ₹50,000 too has been put on hold, along with the requirement for e-commerce portals to deduct tax at source from small sellers. The GST Network, which will digitally capture billions of transactions daily, was not able to test its software in advance; and there is concern about the preparedness of intermediaries mandated to help businesses transition to the completely electronic compliance system. The coming days therefore could test the system, and the capacity of the authorities to think on their feet will be vital.
Indien ist eben weiter als Europa - eine Schande für unsere überbezahlten und untätigen Politiker.
Das Problem ist hier nicht nur der unterschiedliche Satz sondern auch, daß ein grenzüberschreitender Umsatzsteuerbetrug herrscht.
Oder anders: Eine Steuer entsteht durch:
Steuersachverhalt * Steuersatz
Wenn in einem Land unterschiedliche Sätze herrschen und wenn die Waren in ein anderes Land in haushaltsüblichen Mengen durch Privatpersonen mitgenommen werden, sind die Auswirkungen gering; werden die Waren gewerbsmäßig über die Grenze geliefert, sind im Zielland die Steuersätze gleich.
Anders sind die mannigfaltigen Fälle, wo man am Steuersachverhalt rumdreht: Das Finanzamt bekommt den zu wenig zu selten mit oder es ist zwar eine Ausgangsrechnung geschrieben, die an sich dazu führt, daß Steuer abzuführen ist, doch wird die Steuer nicht abgeführt, weil etwa das Unternehmen pleite ist. Auf der andern Seite muß das Finanzamt die Vorsteuer auszahlen ....
Diese Problematik tritt gehäuft mit grenzüberschreitenden Lieferungen auf. Indien versucht das, mit einer einheitlichen Steuer zu umgehen, aber ob die Finanzämter in dem einen Bundesstaat alles mitkriegen was in anderen Bundesstaaten läuft, wage ich zu bezweifeln.
Re: neues Mehrwertsteuersystem in Indien ab heute
The GST Network, which will digitally capture billions of transactions daily, was not able to test its software in advance; and there is concern about the preparedness...
Diesen "concern" teile ich und es stellt sich die Frage, ob die Digitalisierung des Steuersystems schnell zu einem Erfolg führen wird.
Vor ca. einem Monat führte Indien in diesem Zusammenhang ein neues Zollsystem ein, dass so "erfolgreich" war, dass es nach wenigen Tagen wieder eingestellt wurde. Seit dem hängen zigtausende von Zollsendungen im Zoll fest. Dazu kommt, dass ein Importer bevor er seine Sendung in Empfang nehmen kann beim Zoll erst einmal einen Code beantragen muss, damit er an seine Waren kommt und die Warenempfänger haben noch überhaupt keine Idee, was auf sie zu kommt. Eine Bürokratie wird mit einer anderen abgeschafft. Das wird noch Monate dauern, bis das halbwegs zu laufen beginnt.
Wer, wenn nicht die Inder können die entsprechende Software schreiben? Sie haben ja auch die Software für all die grössten internationalen Börsen geschrieben. Allein die Frankfurter Börse kann damit mehrere Milliarden Transaktionen pro Tag verarbeiten…
Bäärti hat geschrieben:Sie haben ja auch die Software für all die grössten internationalen Börsen geschrieben.
Diese internationalen Börsen sind Kunden, die eine klare Vorstellung hatten, wie die Software funktionieren bzw. was sie leisten soll. Es wurden Requirements und Business Rules definiert, welche die indischen Programmierer umsetzen mussten.
Anders bei der Zoll- und Steuersoftware in Indien. Sie wollen etwas Neuen, haben aber keine Ahnung, wie das im Detail funktionieren soll. Ein Programmierer kann auch nur das umsetzen, was der Kunde haben möchte. Natürlich kann er Vorschläge machen und beratend einwirken. Wenn der Kunde aber schon keine klaren Vorstellungen hat, wie soll der Programmierer das umsetzen?
markus-1969
naja was braucht man denn:
1) Den Tatbestand: Lieferung der Ware oder Erbringung einer Dienstleistung ?
2) Den Wert bzw. den Gegenstand der Ware getrennt nach steuerbaren Sachverhalten (unterschiedliche Steuersätze) bzw. die Art der Dienstleistung (unterschiedliche Steuersätze)
3) Den Ort der Lieferung bzw. Leistungserbringung bzw. einen Sachverhalt mit Auslandsbezug
4) Die Steuer - ID des Liefernden bzw. des Leistungserbringers und die Steuer - ID des Kunden und eine ID daraus für das jeweilige Geschäft
5) Entweder man macht es so, daß die Lieferung dann steuerfrei ist wenn eine ID da ist oder man nimmt die ID und sagt "unter dieser ID ist die Steuer zu zahlen"
6) Wenn die Steuer durch den Lieferer bezahlt ist, bekommt sie der gutgeschrieben, der die Ware bezogen bzw. Leistung erhalten hat - über die ID
7) Man erarbeite eine Möglichkeit für Mehrfachkonstellationen: A verkauft an B, B an C, C an D und alle manchen aus, daß A direkt an D liefert.
sooo kompliziert ist das auch nicht.
Dein Wissen um das Zollgeschäfft ist doch sehr lückenhaft. Wenn es so einfach wäre, bräuchte man nicht soviele Vorschriften.
Wenn es nur so einfach wäre. Aber dem ist nicht so. Es gibt verschiedene Schwellenwerte, die eine unterschiedliche Zollabwicklung erforderlich machen. Welche Waren werden importiert. Dürfen sie nur beschränkt importiert werden? Für Metalle und Edelsteine gelten wieder andere Vorschriften. Dazu müssen die Dokumente vollständig sein, was elektronisch geprüft wird, da Dokumente geimaged per EDI an den Zoll übertragen werden müssen. Für bestimmte Waren wird z.B. ein Certificate of Origin benötigt. Wer führt die Verzollung durch und wie? Ist ein POA notwendig?
Der Zollverkehr ist so einfach, dass man von unterschiedlichen Zollbehörden unterschiedliche Auskünfte bekommt. Das Ganze dann einer Software beizubringen stellt eine ganz andere Herausforderung dar.
markus-1969
Sicher. Nur so lange man innerhalb eines Landes Waren umschlägt, hat das mit Zoll nichts zu tun, da Zoll nur an der Außengrenze (z. B. Außengrenze der EU - Zollunion) erhoben wird.
Und das neue System in Indien soll anscheinend auch de-facto-Binnenzölle an den Grenzen der einzelnen Bundesstaaten abschaffen.
Natürlich hat das etwas mit Zoll zu tun, da die GST Einführung nicht nur den Binnen- sondern auch den Zollverkehr betrifft. Da der Importer sich erst einen GST Code besorgen muss, wird es monatelang Chaos geben und die Warehouses des indischen Zolls werden sich mit Zollsendungen füllen, da Sendungen von Empfängern, die nicht GST compliant sind automatisch in Customs Hold gehen. Danach wird der indische Zoll hoffnungslos überfordert sein, denn sie müssen den angehäuften Backlog erst mal abarbeiten. Und das wird nochmal eine Zeit dauern. Dazu müssen Zollprogramme und GST Software miteinander kommunizieren. Da kommen noch spannende Zeiten auf den Zoll und den Importern zu.
